41 - 47 of 47 Posts
HOW DO YOU ADJUST THE clutch cylinder rod ?
You don't with the OE, no way to. There re other Hyundai models that do have the adjustable rod and you can easily replace the rod in your OE one with the adjustable one. Seem to me it was older Tucson.
EDIT not a Tucson an I35.
Tool Material property Electric blue Metal Metalworking hand tool
Audio equipment Automotive tire Font Eyelash Publication
THIS? i do not know if is a better or worst master cilinder.
Clutch master cylinder 41605-2S000 for HYUNDAI ix35 LM EL ELH KIA SPORTAGE III(SL)
Circuit component Font Line Cable Electric blue
Audio equipment Auto part Gadget Composite material Engineering
Auto part Fashion accessory Metal Glass Synthetic rubber
Tool Nozzle Pliers Machine Pipe
Genesis Coupe OEM
Font Line Auto part Automotive exterior Camera accessory
I would look for a used clutch cylinder with the adjustable rod on eBay instead of buying new. It's easy to swap the rod out. can get a used one and just swap the adjustable rod in what you have. As long as you can see a nut on the rod it's adjustable. Don't know why they left it off the Gen Coupe.
41 - 47 of 47 Posts
