1 - 15 of 15 Posts
My Genesis coupe currently has a really bad leak somewhere and water is pooling up in the trunk. I'm going to pinpoint the the point of entry later tonight.
My question is, has anyone on this forum brought their Genesis to a dealership to get the problem fixed under warranty?
I've had nothing but bad experiences with my dealership and I fully expect them to say that can't find any problem and charge me a service fee.
Any input is greatly appreciated
I don't have an answer for you on your water problem but I would sure like to know what you find out as the cause because I've seen other people with the same problem but I've never found out what the cause is of this I've heard it's around the tail lights the antenna fan the sunroof all kinds of different things and I really have never heard anybody nail it down to what it actually is so if you do please let me know I would appreciate good luck thanks Danny
Sent from my VS985 4G using Tapatalk
Most of these is the taillight gasket/seal. I had the water in the trunk and into the back seat floor. Dealer replaced the "updated in 2014" gasket/seals for the taillight and has been okay so far. Pryor to getting the gaskets replaced, I, like many others put tape over the top of the taillights to seal the crack from the top. That also worked, but the take needs to replaced when it starts to look $htty.
GL
ominousone
I have same issue. Does the water pool up under the spare wheel? My Hyundai dealership will check if it’s under warranty for $150 so I just keep a sponge handy.
Things to check if there is a leak in the trunk.
Tail lights
trunk seals
If you have a sunroof, to see if the drains from it are clogged.
I was just gonna say, my buddy had his parked under a tree with tiny leaves and when the fall rains came, it all built up. Having a garage certainly helps to keep the problem at bay
I had this issue and did many things. Taped the top of tail lights, removed the liner and caulked the inner sides where the factory seam sealer is. Finally I did something that worked but not 100% sure? I would remove or pull back the trunk liner carpet and look for signs of wetness or dirt build up, typically it will be one side or the other.
I did everything I could do with the tail lights I put everything around there that you can imagine to try and seal that leak that keeps constantly coming in I never did get it fixed tomorrow mine's going to be sold I'm going to be leaving The Forum but I would like to thank raspberry and Titan for their help that they helped me with their knowledge I'm sure will help me any of you guys out there it's a great form keep it going I'm going to keep it on anyway I want somebody to find out where it's leaking at cuz it's a bad problem for a good a great car I'm going to keep updated here on the form even though the car is going to be gone and I wish you guys luck so keep getting no speeding tickets and peace out thank you Danny
I had the same problem as well a couple months ago. It pooled up in my trunk under the spare tire and eventually spread all the way up to my gas pedal completely under my carpet. I had to take out all my carpet and seats and center console to let everything air out and then test it under a water hose for a long time to realize it was in fact coming in around the taillights. I had had a few people on instagram tell me they had the same thing happen and it was their taillights, but I just wanted to be sure. I used some gasket maker around my taillights and sealed them up and haven't had any problems since. Only problem is I'm too lazy to put my carpet back in.xD
Same issue here! Every time it rains and I’m driving I can hear a lot of back splash under my car & by the time I get to where ever I’m going my trunk is filled with water. Especially in the cornered areas of my trunk.....like a lot of water. I’ll try to take some pics next time it rains here in jersey but this **** is annoying every time it rains I’m in my trunk laying down towels
I had the same issue
I added Gorilla tape to the seal area to make it thicket. One year later still dry even in Florida Rain
Any chance you can describe exactly where you applied this sealer and what kind?
1 - 15 of 15 Posts
