1 - 13 of 13 Posts
Boost your Genesis with Major Power Increase​
AEM strived to create an aftermarket performance component with OEM fitment and finish when possible OEM clearances were maintained to critical systems found in the engine compartment of the Coupe.
ON LIMITED STOCK
Price too low to list, click here!
Testing of the AEM Front Mount Intercooler Kit for the Genesis Coupe has revealed
valuable performance data.
the volume of the intercooler core is doubled
This massive increase in volume results into greatly improved heat transfer,
which in turn significantly reduces inlet air temperatures
ON LIMITED STOCK
The 26-2100C intercooler kit is a comprehensive bolt-on air cooling system, it contains everything that is necessary for installation down to the couplers, clamps, and brackets. At the heart of the system, a large bar-and-plate intercooler core was chosen to replace the factory Hyundai intercooler. The AEM intercooler core is capped on both ends with end tanks that are optimized to evenly distribute airflow across the core.
ON LIMITED STOCK
As an added benefit, a mounting pad is incorporated onto the charge pipe just before the throttle body. This mounting pad can be utilized to easily plumb water/methanol injection systems into the air inlet tract. This is especially useful for high boost pressure applications and vehicles used in hot climates.
ON LIMITED STOCK
MAKE SURE TO VISIT GENESISTUNERS.COM FOR MORE GENESIS COUPE PARTS!
1 - 13 of 13 Posts
