Korean Asswhoopin
Anyone have expereince with either the Bosch 750s or Fuel Injector Clinic 775s?
that guy
I have Bosch 750cc's, they will be going in this week! I'll let you know how they work out
2.0 MT - Shanghai
I have Siemens 750, most of the times (and mistakenly) they are called Bosch. They work perfectly. You'll find pics in my build thread if you want to see what they look like. Got if from fiveO.
Jedi Master
if you ever run a stage 3 meth kit that taps into the flue interctor power line to run DC off the fuel injector DC, then you will want fic because it comes with a harness adapter that will allow you to tap into without needing to tap into the stocke cu harness
I only use ID injectors.
ID , fiveo motorsports and DW all use ev14 injector and then rework them; With ID,they also give you all the info your tuner needs, dead times at all fuel pressures and all voltages.
Having said that 750 cc are small injectors and you wouldn't notice much if any difference between them as far as tuning goes, just a little longer to dial in.
Over 1000 cc totally different story.
| Boost Addict |
Im using Bosch 750cc and loving them!
