1 - 2 of 2 Posts
So I recently bought a block off plate to replace my factory bpv. I installed the block off plate just fine, everything is tight. And I plugged the vacuum line that was plugged into the old bpv. I was expecting an engine light with this mod, but now I can’t drive for more than 5 minutes without my car going into limp mode. Is this something I can stop from happening myself or do I need to talk to a tuner?
Did you install a blow off valve anywhere? If you just put a block off plate all that pressure has no where to go except the wrong way through the turbo...
You use the bypass valve to recirculate that pressure back through the front of the turbo. OR you blow it off to atmosphere. Just blocking off the pipe is not advised.
1 - 2 of 2 Posts
