Hey Guys,
Just curious what fluid everyone is using when they flush their brake fluid?
I plan on replacing it in the spring and looking at some ATE Super Dot 4, Class 6 brake fluid. It's a premium brake fluid, however I noticed it is low viscosity. Just curious if this would still be ok?, and if anyone has noticed any wear and tear on the ABS modual, seal leaks, or any long term effects?
The OEM spec is Dot 3, so obviously Dot 4 is a slight upgrade, however I am alittle leery about using a lower viscosity, I am concerned about additional wear or long-term effect from using it.
ATE Super Dot 4 (minimum)
Boiling point - 265 DegC (509degF)
Wet Boiling point - 175 DegC (347degF)
I know it seems dismal to debate different fluids and their specs, however I find it very interesting when someone can find a better fluid for the same price as a brand name...........I try to look past the marketing, and look at a fluids real qualities, rather than it's fancy packaging.
ALWAYS REMEMBER - A small change such as a fluid can make a huge difference in a products longevity and performance.
Duro
Duro
