Okay so my issue is with my brake lights. I replaced all the lights in the back with LED lights from Diode Dynamics. And I also got a brake switch recall from my dealership. So I took my car and got the recall taken care of, and in my boredom later that day I decided to put my LED lights in. I swapped out the brake lights, reverse lights and signal lights. I did not change the brake light in the rear window. That's when my issue started. When my headlights are off, everything is as it should be, a normal system. But when my headlights are on, all three of my brake lights come on. And yes it is my brake lights, not just the running lights that are supposed to come on with your headlights. So I decided to play a little bit. I got in, turned my headlights on, and pressed the start button. I did not have to press the brake to start the car. I put it into gear without having to press the brake, and when I am driving, I don't have any cruise control cause the car thinks the brake is on and says nope. These problems are only when I have the headlights turned on. And yes I installed LED resistors in all the bulbs I replaced. So could this be something I did with the lights or could the dealership have done something wrong when they did the recall?
