1 - 10 of 10 Posts
So I installed an adjustable clutch rod with a new master cylinder and a SS clutch line. When I got done bleeding I noticed there was a leak under the master cylinder. Its coming from where the hard line goes into the master cylinder.
It's seeping out of where the clip goes. I didn't have to loosen anything to remove the old one besides the clip.
I have no idea how to go about it.
Grey Wood Cash Personal protective equipment Currency
I don't know if it even has an oring. Maybe a teflon seal or something. Have you tried to tighten it? Is it cross threaded? Is it where it screws/clips into the clutch master cylinder?
Discussion Starter · #8 ·
So I cut the master cylinder in half since it was messed up anyway. Here are some of the pictures I got, also the O-ring for the hard line fitting to master clutch cylinder discharge outlet was cut .
I saw this on another thread. You can see the small O-ring on the fitting.
I tried tightening but it wouldn't really budge but I didn't have to loosen it to get the old MC off. I'd have to take the ecu out again to really get in there. It's literally just held on with a little c clip.
For anyone wondering, I got an O ring kit with a bunch of different sizes and tried them all on the fitting on the hard line since the old one was definitely shot. None of them fit right so I got a brand new hard line. I also got another new master cylinder just to be sure.
Fishing the hardline through was definitely a pain but I got everything put in and the leak is gone. Bleeding took awhile but glad it got fixed.
1 - 10 of 10 Posts
