1 - 5 of 5 Posts
Anyone ever have to replace the airbag light harness clip thingy? lol, I'm pretty sure I broke it taking it off when I fixing some wires behind my head unit. The clip behind the light still works, I can plug it in and unplug it but it doesn't register that it's there so the light stays on. Any ideas? Cause I don't want this stupid light in my dash.. Thanks guys
you might have to reset that. did you unplug your battery when you were installing the new HU?
Korean Asswhoopin
Probably keyed on with harness unplugged. Needs cleared with a scanner. If the light lights up like it should then probably nothing actually broken
You were able to plug it back in properly?
Try this unhook the battery and wait a few minutes to see if that resets it. Also check the fuse box for SRS airbag fuses, try pulling that out and see if that works. Finally have someone sit in the passenger seat start the car to see if the airbag light goes off as well.
1 - 5 of 5 Posts
