1 - 3 of 3 Posts
2010 3.8 Std Trans
I am not sure who won. He was huge with the emphasis on "was", now he is a mess. He ran out on a hard curve with a bit of gravel on it and trees right on the edges of said road/curve. So I was only able to hit the brakes and hope he outran me, that made it worse since the nose was a bit lower thanks to the braking.
That line is a crack that opens up if you push from the back of the bumper. Any tips on preventing the paint damage from spreading? It has a few ripple looking marks moving away from the crack. I was thinking about using some epoxy to keeping that crack from getting bigger, etc.
Drill a hole where the crack stops. Just use a small drill bit, 3/16" or 1/4". Did this all the time riding dirt bikes when you crack your plastics. It redirects the forces so as to prevent further cracking.
1 - 3 of 3 Posts
