1 - 5 of 5 Posts
Hello,
2010 2.0t r-spec and the window regulator broke today on the way home. Took the door apart, and everything is fine except this one plastic part of the pulley system in the window regulator. (In central florida, so the plastic probably just got too hot, and was an easy snap for the metal cables)
I've been looking online, and can only find the full regulator (big metal door piece, with pulley cables and everything) when all i really need is this thing to get it all right. Anybody know how/where to get the single piece online, or am I stuck getting the 60-200$ system?
Also, sorry if post is in wrong section, I can delete and re-post if necessary :)
IF you can read the Hyundai part # on the part, you can try contacting a dealer to see if it's available separately.
If not, the junk yard is your friend.
That might not be sold separately. Like others said, junkyard or dealer. Maybe you can run the part number for the whole assembly and find what other cars use it.
1 - 5 of 5 Posts
