1 - 1 of 1 Posts
So my bk1 3.8 threw a sorts of codes a few weeks ago. I thought it was maybe the battery about to go so I replaced it but the codes came back.
Does anyone know if its the ECU on its last legs or a simple fix? Or something else? Some of the codes are below
DTC
C1604-ECU hardware error
C1101-Battery Voltage High
C1102-Battery Voltage Low
C1260-Steering Angle Sensor Circuit Signal
C1503-TCS/ESC SWITCH ERROR
C1283-Yaw rate & G Sensor Signal
C1616-Can Bus off
And a few others.
Airbag Event 1 & 2
B1102- Battery voltage to low
B1352- Passanger airbag resistance too high
And basically all the same for all the other airbags.
1 - 1 of 1 Posts
