1 - 8 of 8 Posts
My car won’t go over 3500 rpm whenever the abs and traction light comes on. Anyone have any idea what it could be. Air fuel ratio also jumps around a lot
did you have the tires rotated or tires changed?
tires can only be rotated left and right if non directional.
rear tires have to larger than the fronts. The car is programmed for a staggered wheel setup.
Tire pressure? that, a TPMS sensor, or a wheel speed sensor not working can cause it.
the wheel speed sensors are the ABS sensors too.
Did you have any work done on the car recently?
Discussion Starter #7
I checked all the cables removed them to see if any cables are bad. That’s all I did. What’s the right what to check it?
1 - 8 of 8 Posts
