21 - 40 of 80 Posts
Ok well I think I found part of the problem. It does show 4.19v so I will still adjust the rod down but plan on dropping some hot glue on this when complete....
Koziollz could take a picture of where you probed? I'm having the same issue so I'm trying to test. If you can also shoot me a pic of your turbo setup that would help immensely
The green wire that is frayed in my photo above is where I probed.
I have a stock turbo setup, just CAI exhaust and tune....bov is back to stock as well
I am now getting P2564 code and same symptoms.
I went 1 full rotation outward, to no avail.
I put it back to stock location and tightened the bolts, to no avail.
Waiting for the engine to cool down will try 1 rotation inward and check again.......this is getting frustrating!
I'm on the same boat. Was getting both codes and now after adjusting get no code but no boost.
Has anyone been able to resolve this? I replaced my wastegate connector and now getting P2562 and no boost.....
Guys, I'm now also in the same boat as both of you. I'll getting a P2563 "Turbocharger Boost Control Position Sensor Circuit Range/Performance"...
I haven't measured the voltage yet but the OP had a different code pop - does the TSB really have anything to do with us? Just wondering if we should be focusing somewhere else.
I will check voltage right now.
- Marco
The Gen Coupe is back!!!!
For those of you that have been following my CEL/boost/limp mode problems I finally resolved them and cleared the CELs. First I replaced and soldered the electronic wastegate connector, still had issues. This morning I replaced the whole electronic wastegate and arm, cleared the CELs via torque, and I'm back in business. Boosting again and BTR tune is running nice.
Reinstalled the BOV adapter after a couple initial test drives, all gravy!!!!
Nice - same with me - replaced EWG and life is good.
Well I just threw codes P0035,P259F, and P2562
the wires aren't frayed, the insulation is coming off the wires.
I wouldn't use hot glue.... It will be around hot parts.
Just get some liquid electric tape.
They ended up being frayed eventually, can't tell in the photo. I ended up replacing the whole connector, new solder and made sure to do a really nice solid job. Was still throwing the code and no boost. Had to replace the electronic waste gate and that took care of it.
tldr: replaced electronic waste gate & soldered replacement connector: All Set!
shouldn't solder connections that'll be around exhaust components.
User small gauge crimp connections, with shrink tubing.
the best solution is if there's enough slack, to crimp new pins onto the wires, and re-pin the connector.
There wasn't enough slack and I couldn't repin this connector. It's a whacky one. I did use shrink tubing and route the wire as far from exhaust components as possible. Seems to be a solid connection so far.
21 - 40 of 80 Posts
