41 - 60 of 80 Posts
I don't think people realize how crappie these connections and wires are from the factory.
im having the same problem. i have a p2563 and p2564. im planning on just buying the EWG. do you guys know the part number for the EWG that you installed and was the installation easy? i really dont want to go to the dealership. Thanks
on my way home and will pull my invoice out and give you the part number... super ez to swap out and won't take you longer than 10 mins
Thanks a lot man.
Here is the part # for Electric Waste Gate Actuator (2013 - assume it's the same part for everything 2013 and above): 39400-2C500
It should cost you around $216. Hope that helps.
Thank you so much man I really appreciate the help!
That is the solenoid if it is what you are looking for.
yes i know but for 57$ it seems a little too good to be true. everywhere else its 200+
Sounds like the +200 is either a different part or a ripoff.
Okay so this part is the Electric Wastegate Actuator? or solenoid? sorry im a noob whats the difference? Im sure i need a new electronic wastegate
Well it sounds like you need to contact the sellers.......
The 4Green site has online chat if you want to drill them about the right part.
alright man thanks for all the help. :grin:
so i installed the new wastegate and everything was good for about two weeks. now i have the same code and i actually bought another new wastegate but this time i still have the code and no boost. any ideas?
yep... your turbo is shot. How many miles on the car? I had to replace mine at 93000 miles.
41 - 60 of 80 Posts
