1 - 20 of 64 Posts
Knows some stuff...
Discussion Starter #1 (Edited by Moderator)
I don't really want to get a bunch of opinions or reviews or experiences with brands ect. in this thread, this is purely for facts/specs/info please. You come here, look at the specs, find what you like, narrow it down and THEN you can do a search on the forum or make a thread to check on their reputation, chatter, and other info that could help you decide.
Flywheels weight:
OEM DMF: 30 lbs
Exceladyne SMF (Chromoly): 13.6lbs
Exedy SMF (Chrome molly steel): 40lbs (Clutch&FW)
Clutchmasters SMF: 22 lbs
DTMSPEED SMF (alum backing Chromoly face): 17 lbs
SpeedyHouse SMF: ?
Clutchnet: ?
SPEC SMF (alum backing replacable face): 16.7 lbs
Competition SMF (Steel): 16lbs
Clutch materia/Torque rating max (crank lb ft) (or % over stock crank tq):
OEM: Organic/250-350 lbs seems to be people report slipping but if anyone actually has specs, please inform me.
Exceladyne Twin Disc Clutch: Unsprung Ceramic Disks/560lbs
Exedy's new Twin Disk: Sprung ceramitallic friction plates/500-600 lbs
SpeedyHouse Twin Disk: Unsprung Ceramic 6 Puck/?
DTMSPEED Stage 4 Clutch: 5 or 6 puck ceramic-cintered/ 650 lbs
SPEC Stage 1: Steel-backed and multi-compound woven organic material/420 lbs
SPEC Stage 2: Pure Kevlar friction material/490 lbs
SPEC Stage 2+: Hybrid Kevlar and Carbon-Graphite Friction material/543 lbs
SPEC Stage 3: Carbon-Graphite Friction Material/616 lbs
SPEC Stage 3+: Carbon semi-metallic friction material/688 lbs
SPEC Stage 4: Carbon-Graphite Friction Material/616 lbs
SPEC Stage 5: Full-metallic friction material/815 lbs
ClutchMasters Stage 1: Steel-Backed Organic/70% Increase
ClutchMasters Stage 2: Full Faced Kevlar/70% Increase
ClutchMasters Stage 3: Segmented Kevlar/110% Increase
ClutchMasters Stage 4: Ceramic 4 Puck or Ceramic 6 Puck/170% Increase
ClutchMasters Stage 5: Unsprung Ceramic 4 puck, 6 puck, or sintered iron/200-400% Increase
Competiton Clutch Stage 2: Steelback Brass/80% Increase
Competiton Clutch Stage 3: Segmented Kevlar/150% Increase
Competition Clutch Stage 3: Segmented Cermamic/150% Increase
Competiton Clutch Stage 3 Ironman: Iron 6 Puck/175% Increase
Competiton Clutch Stage 4: Sprung or unsprung Ceramic 6 Puck/250% Increase
Competiton Clutch Stage 5: Sprung or unsprung Ceramic 4 puck/300% Increase
PP Material/Force:
OEM : ?/1200lbs
Exceladyne: ?/?
Exedy: ?/?
Clutchmasters: cast ductile iron/?
DTMSPEED : Aluminum/2200-2400 lbs
SpeedyHouse: Aluminum/?
SPEC: ?/?
Competition: Steel/2700lbs
PBIR stg3+: ?/2800 lbs
Price:
Exceladyne Twin Disc Clutch + PP + Flywheel: ~$2300
Exedy's new Twin Disk + PP + Flywheel: $1800
SpeedyHouse Twin Disk + PP + TOB: Projected $1600-$1900.
DTMSPEED Stage 4 clutch + PP + Flywheel: $1600
SPEC Flywheel: $530
SPEC Stage 1+ PP: $500
SPEC Stage 2+ PP:$546
SPEC Stage 2+ + PP:$560
SPEC Stage 3+ PP:$530
SPEC Stage 3+ + PP:$646
SPEC Stage 4+ PP:$530
SPEC Stage 5+ PP:$700
ClutchMasters flywheel: $960
ClutchMasters Stage 1+ PP: $575
ClutchMasters Stage 2+ PP: $645
ClutchMasters Stage 3+ PP: $645
ClutchMasters Stage 4+ PP: $645
ClutchMasters Stage 5+ PP: $575
Competiton Clutch Stage 2 + PP: $895
Competiton Clutch Stage 3 + PP: $995
Competition Clutch Stage 3 Ironman + PP:995
Competiton Clutch Stage 4 + PP: $895
Competiton Clutch Stage 5 + PP: $895
Clutchnet:?
DMF= Dual Mass Flywheel
SMF= Single Mass Flywheel
I am not going to classify any ALF (aftermarket lighweight flywheel) as that is really subjective. The weights are listed, you decide if it is a SMF or ALF.
PP=Pressure Plate
TOB= Throw Out Bearing
The tool you need for taking the flywheel off is a torx tool. labeled T-60 is the name of the tool. you can pick that up almost any auto store or ace.
Thanks to SoCalturbo, Adamantine, Quartermaster, Snoopy0812, and Tony20tGen, BadBoyBill, whatever210 for their help in aquiring some of the info.
And due to the inability to only post info/specs and not opinions or questions, I am requesting this thread be locked and if you have any updates or edits, please PM a mod and they have the ability to add/fix and add your name to the bottom for your contribution. RCP, rtermaster, Snoopy0812, and Tony20tGens help in aquiring the info.
Super Moderator
I was just going by what whatnot had posted above as OEM
OEM: Organic/250-350 lbs seems to be where they slip.
The OEM clutch is far from consistant but I used those numbers to demonstrate how the % would work. There have been a small group of people that are pushing 350ft-lbs and still on a non-slipping OEM clutch, but I wouldn't trust it at that high of torque.
Knows some stuff...
I am pretty sure the companies are using crank specs as well, though it was jsut a guess.
Torque Junky
i was told by a rep at PBIR that stg3+ up had 2800# pp force
It is not red. Not red..
Bump.
Any new info on clutches? I'll be in the market shortly.. :hello:
Hopefully Centerforce or RPS Clutches will have something for the masses. I really haven't had too good of luck with SPEC.
FUNCTION OVER FORM
Beyond Redline Twin Disc
I'm fixin to install my BR twin disc & will give details soon, although I know the price is more than most are willing to spend. I have Redline MT85 fluid & new OEM slave cylinder/throw out bearing ordered already... My OEM flywheel feels like it is about to come apart. :squint:
Exceladyne flywheel weight 13.6 lbs
Exceladyne clutch assy weight 14.4 lbs
buy me some race gas!
ill jus put his here cause this seems that know one knows or has a hard time finding it.
18-26 lbs for the clutch cover and 75-85 for the flywheel.
the tool you need for taking the flywheel off is a torx tool. labeled T-60 is the name of the tool. you can pick that up almost any auto store or ace where i got mine.
Knows some stuff...
Discussion Starter #10
This thread was made to help people when clutch shopping, though I just want facts, and not opinions (there is enough threads out there on that), so pictures are factual, and if could help a purchase, so sure, post them up. and if you don't mind putting up other pics you have found to try and get all the pics in one post somewhat broken down/seperated like I did.
Though the OP is expired so I can't change it anymore with out the assistance of a mod.
If not I will try to search and find some pics and post them when I get some time, just been busy traveling lately.
thanks.
does the genesis have a clutch delay valve
Knows some stuff...
Discussion Starter #14
Can I get a mod to update the OP to Exedy FW to Chrome molly steel, the price to $1800, and the holding force to be 500-600tq, with sprung ceramitallic friction plates
thanks
thanks
Weight for the Exedy twin disk clutch kit. Is about 40 pounds
BioHazard Risk !
This thread is really a good idea !
Herpes Free!
Thanks for this thread. Can we ask question here or should I post a new thread?
This might be a silly question but if the Clutch is calling for 110% over stock, does that mean that a 200HP vehicle would only be rated for 220HP or 420?
Thanx
Knows some stuff...
Discussion Starter #20
^^ 420 is % over stock, 220 would be % of stock, it is the first one, the 420.
If it was 220, then those selling 70% would be less than stock lol, so you can see right away that logic doesn't work. It says % over stock, not % of stock.
1 - 20 of 64 Posts
