1 - 2 of 2 Posts
Hi all. Thanks in advance for your time. I'm having issues with the radio making popping sounds and the display gets scrambled when the weather gets cold. The Bluetooth will also disconnect. Once it warms up, it is fine for most of the time. I would think that the only way to fix this would be to replace the radio unit and display but I wanted to see if this may be a common issue or if someone else has run into this problem.
Thanks again.
1 - 2 of 2 Posts
