I'm not sure if many changed the ATF fluid but after doing some research, I managed to find 2 alternative ATF fluids that are compatible with the Apolloil Red-1k. Proof is shown the fluids' technical data sheets.
1) Havoline Multi ATF
http://www.havoline.com/na/docs/Multi-Vehicle_ATF_PDS.pdf
2) Motul Multi ATF
http://www.motul-oil.co.uk/pdfs/gear-oil/Multi_ATF_TDS_(GB).pdf
2) Motul Multi ATF
