In my case, I did not drain it.
I did an engine swap. When you remove the torque converter, you remove some ATF.
I just topped off mine.
If you remove the engine, or do anything that disconnects the transcooler/radiator (there is a transcooler built into the radiator, in addition to the supplemental external transcooler) lines, you need to top it off.
