That squeaking noise is the belt. Condensation accumulates on the smooth portion of the belt and causes a chirp until the condensation dissipates, this is commonly referred to as tensioner "morning sickness".
Thanks for the input!! It definitely makes sense now. The weird thing is that this has never happened on cars that I've owned before.That squeaking noise is the belt. Condensation accumulates on the smooth portion of the belt and causes a chirp until the condensation dissipates, this is commonly referred to as tensioner "morning sickness".
That's what I'm thinking it is. Probably condensation since the engine is cold and water starts dripping when it warms up.cold walter leak , , leak wen its cold stops when it warm
I'm quite sure the A/C is off. As a matter of fact, I do think it is condensation. But not really condensation because it is not pure water. When I run my finger on the spot, there is a little green texture in it and it smells like coolant and condensed water. I check the coolant level everyday and I don't see any decrease in it.Is the AC on when you warm up? If so, thats not coolant, thats water thats being extracted out of the air by the AC condenser and drained out by means of the drain tube in the trans tunnel.
Its normal.
Stick a paper towel into it or put a large white sheet of paper under it. If its clear and does not smell,its probably water. If its colored and/or smells then it may be coolant. Does anyone offhand know what color of coolant hyundai uses?Here's a pic of the leak to give a clear idea:
I would buy the idea of water leaking because of condensation. But that coolant in there makes no sense because it only leaks in the morning or whenever the car is warming up.
I didn't touch anything anywhere. It is leaking from the driver's side of the engine bay. I made a general search on the web and some posted that it might be a bad thermostat hose. This might be the cause because it only happens when the car is warming up. So I think that the thermostat is related to it.Which part of the engine compartment is it leaking from.
You touch anything in the engine compartment?
Towards the back of the engine = heater/back of head
mid engine = turbo (more of the weird jumble of hose that leads to/from the turbo and water pump)
front = radiator or water pump.
I did that. It is mostly clear, but had a little green texture and a faint coolant smell.Stick a paper towel into it or put a large white sheet of paper under it. If its clear and does not smell,its probably water. If its colored and/or smells then it may be coolant. Does anyone offhand know what color of coolant hyundai uses?
Driver's side of the engine.That is definitely coolant.
What side of the engine is it coming from?
