1 - 14 of 14 Posts
GCMafia
Wow!! Should have waited two years too buy this! Hahaha good deal! Some people sell this used for that Much!
2012 3.8 Track ZF-6-SPD
This is a good deal. Any difference for the Auto guys.
Sleeper!
This question may have already been asked, but I have "searched" and nothing came up. I notice you don't have the motor mounts or rear diff mount listed under the 2013, only the 2010-2012 years. Are the mounts completely different or similar? If different, any ETA on the 2013 arrival? Thank You
2013 2.0T's use the V6 motor mounts. A member already went through this and found out that Hyundai had swapped out the subframe for 2013 to the V6 subframe, going from 3 bolt lower mounts to single bolt lower mounts.
Jedi Master
other then manufactor cos, is there a design reason for this?
honestly, no clue. I could speculate if you'd like but I'd have to research engine bushings a bit more to do it justice. I'd assume though that more than likely it's done just to save costs. One less subframe to stock and one less bushing type.
Jedi Master
cp-e the 50d is out of stock can you post one's it's back in stock?
Is 50d the softer one?
Sleeper!
So your saying they kept the subframe the same as the previous years for the 13 v6?
Discussion Starter · #11 ·
They're not 100% identical no as the bushings were revised like the rest of them and some mounting points for accessories changed but you can use 2010 motor mounts on the 2013 V6.
Sleeper!
Ok thank you for the info Snoopy much appreciated.
Jedi Master
still no mount avaible?
1 - 14 of 14 Posts
