1 - 20 of 1909 Posts
Old Man Guru
Hello guys, I'm new here and don't have a GenCoupe :hello:. But I am very interested in it; to me it is a new Nissan Silvia with Mitsubishi Evolution heritage. And since I grew up on Evo's (and 4 Eclipse GSX's before that), and still have one as my daily driver...this new GenCoupe is interesting. The only thing that puts me off is the inability to fully tune the car by myself. I love what PowerAXEL has done, but sorry, nothing beats me spending hundreds of hours logging and tuning; no matter how good the tuner is a 1hr dyno tune still isn't close and certainly an off the shelf map can't come close.
In the Evo community this was once the same problem, but the community came together and cracked the ECU and now there are plugin mods for the stock ECU to make it do some crazy things. People are even hitting 800hp on the stock ECU :eek:!
So I decided to see if I could get the ball rolling on the same thing for the GenCoupe community. Now, I'm not a hacker or a programmer (though I do have an EE/ME background). And I have never done this before. But I decided to take a look at the problem and see what I could find. In 3 days I have found the following:
  1. The 2.0t Genesis Coupe is running the Siemens VDO 5WY5D75A SIM2K-141 ECU.
  2. To pull the ROM off the ECU you will need a K-Line compatible OBD2 reader and KWP2000 (Keyword Protocol 2000) software.
  3. To write the ROM back to the ECU you need a K-Line and L-Line compatible OBD2 reader and KWP2000 (Keyword Protocol 2000) software.
---The above is the easy part. There are plenty of KWP2000 software packages out there and plenty of K/L Line compatible OBD2 readers. I actually have the hardware here with me from using it on my Evo (Open Port 2.0x is KWP2000 and K/L line compatible)---
  1. I also found at least 2 other people have already started down this road, and both have successfully pulled their ROM's off the ECU via the OBD2 port.
  2. I obtained a copy of both ROM's, one 6sp and one 5sp auto.
  3. I have run an analysis on both raw .BIN files and they share 75% of the same code structure.
  4. I have run the 6sp ROM through a decompiler (IDA Pro), and an automated map identifier (WinOLS) and identified potentially 152 individual maps.
  5. I have a pretty good feeling I have found 4 fuel maps, looks like a "low octane" map for when you are detonating, 2 regular fuel maps, and 1 cold start fuel map. All 4 maps are scaled from 720rpm to 6000rpm by 0 - 870(something). The secondary scaling is definitely load, but I'm unsure of the ECU's raw measurement meathod yet (either Kpa, or MilliBar probably).
  6. I have also found that there is already a checksum definition out there...but it's behind lock and key (ie. $$$$). If you want to search for it via Warez it is "OLS298 - Siemens Simos HMC (Version 2.11)".
Now that's what I have accomplished so far. I'll be glad to share all my work so you can see it too. I've never done this before so I'm very likely wrong on some of my above assumptions (only thing I know I got right for sure was RPM's on the scaling of the maps I have identified hahahahahah :fleshbox:).
This is what I need from the community to make the next big leaps:
1. Documentation on the coding language used for this ECU
2. Documentation on the hardware definitions used by Siemens
With those items we should be able to define the stock ROM in a couple months. We should then be able to see the stock ECU's maps and how it works for the most part. But the big part is Checksum's. I'm tired of typing but I'll explain Checksum's in a bit (after I go shoot someone on Counterstrike to let off some steam). But think of Checksum's as security built into the ROM to prevent anyone from changing anything.
And remember 2 things:
1. Other people have done this before and they started out not knowing anything.
2. PowerAXEL has this all figured out (though they purchased a solution)...so the knowledge on this particular ECU is already out there, we just got to figure it out.
If u don't kno, now u kno
dang son...can you crack the stock 3.8 ECU? i heard it's a beetch....Delphi unit
Retired Staff
Ok.... I don't speak computers or tuning, but anything I can to help, I will.
Major hats off to you sir.
It is not red. Not red..
This thread has potential win.
Old Man Guru
Since I can't post pictures until I hit 10 posts, please consider this gratuitous post whoring. A lot of what I want to explain and show are easier to explain with pictures so :). Also, I have *NOT* cracked anything. I have simply looked at a raw file, and using pattern recognition, identified some *potential* maps. *Cracking* a ROM is more along the lines of cracking the Checksum algorithm...
And remember, this thread is for you guys to get interested in how this all works and to contribute :). As I say at work, "I hope I'm not the smartest guy in the room, cause if I am then we are all screwed".
Just FYI.. You suck at post-whoring.
Old Man Guru
Discussion Starter · #11 ·
I really want to explain Checksums, I'm not trying to put it off...but I need motivation. Off to the ColdStone for a quick Ice Cream and then a post about this crazy lock and key on the ROM.
(and yes, more post whoreing)
You bought the IDA pro? holy crap never knew there was something like this out there. and OLD school Counter Strike! bring back the bunny hop lol.
Old Man Guru
Discussion Starter · #14 ·
I have the Trial of IDA Pro. And yes, I have been playing counterstrike since 1998 (to give away my age a bit :cool:). And nobody does the running man like me...but usually I'm running from the cops :rofl:.
Thought the 2.0T ecu uses a CAN bus data line.
It's how the ECU communicates with all the other modules.
BTW checksum is a form of error correction.
Old Man Guru
Discussion Starter · #17 ·
Ok, since I'm now over 10 posts I can share some of what I have found. Directly below you will see the first definite map I have pulled out of the ROM. This appears that it could be a fuel map, but after looking at it a little more it's definitely not. No fuel map would have the same value at full load across all RPM points. Regardless this is definitely a map from a GenCoupe 6mt ROM. I did identify that one axis is RPM, and one axis is LOAD; though I don't know the load value. I have found 5 more similar maps to this.
Now that we know that is a map the next step is finding the next two major data points. What is the map for, fuel, timing, VVT, etc.....and what is the Z value. Knowing all four items (X,Y,Z and map type) will allow us to finally know what that particular section of the ROM is for.
If you are interested this map is at address 4E2B2 in the .BIN file. This is what the raw part of this file looks like before definition and adding pretty graphics:
CHECKSUM INFORMATION BELOW:
Now, you *could* edit the values of this map and effectively "tune" that map. However there are these things called Checksums. What they are is a cross referenced value to determine if the values in the map are valid or if they are corrupt (hacked). This is an algorithm where the ECU sees at Load 870 and RPM 6000 it needs to give 8000 something according to this map. So the ECU then takes that value of 8000, it's address space, and runs it through a mathematical formula (algorithm). That formula spits out a value, say for example "FE" and the ECU then goes to a specific location in the ROM, another address, and see's if that address equals "FE". If the address equals "FE" then the Checksum has passed and the ECU moves forward. If the Checksum doesn't pass then several things could happen but it all boils down to one final outcome...your modified map doesn't work (and worse you could brick your ECU).
So you can see that identifying the maps are the easy part...cracking the ROM is the hard part.
Subscribed. I really wish I could help, but I can't. But props for working towards cracking the ECU!
Old Man Guru
Discussion Starter · #20 ·
Yes, the 2.0t does use a CAN bus, and you are correct, it's for communicating with other modules. You can also tap into this CAN bus and log what is going on. You can use a Tactrix Open Port 2.0x cable and EVOScan, set the scanner to CAN BUS and then you can datalog your 2.0t. You can't use CAN to flash your car however. It doesn't have the ability to write or read the ROM. Only monitor communications.
To actually flash your ECU you have to use KPW2000 protocol over the ODB2 K-Line and L-Line. Most KPW2000 ECU's can be flashed solely over the K-Line because it is bi-directional serial communication, but some newer ECU's require the use of the unidirectional (inbound to the ECU) L-Line. Since I don't have a GenCoupe I can only guess that L-Line is required since this ECU is so new.
As a side note: There is a LOT of empty space in this ROM. Which is not surprising. But interesting for those of us who have seen what Tephra was able to do with the freespace in the Evo VIII and IX ROM's.
