1 - 16 of 16 Posts
Hi,
I have a depo intercooler kit,its really tight against the subframe causing it to rattle,anyone else with the same problem?
Did any of you found a fix for the map sensor hitting the altenator? Thinking about cutting the wires to extend it...
I installed mine last weekend and I have no issues with it banging anywhere except my k&n filter. Mine was close to the alternator but then I just pulled it out of the throttle body to move it toward the rad more and tightened the t-clamp and it has about 2 inches room all around it.
Here 2 pics.
Pic 1 - Have cardboard on the left side pipe due to rubbing with k&n
Pic 2 - Shot from left side fender toward engine showing space from alternator
Hopefully this helps
thanks but i got the older setup the had issues with the map sensor location,does yours come even close to the subframe in between the rad and subframe
i have depo racing piping w/ my intercooler that i had from my 240, mine does tap against the subframe on the cold pipe, all i did was to slide a piece of silcone piping on the contact points to muffled the rattles, but my intercooler was different size to the depo racing core, so i had to do some hacking and cutting of the piping to make everything fit, but mine also rubs a lil on the bottom mounts of the rad fans, but no noise, i'll hava take it out and play w/ it a bit more later when it gets warmer
You can actually hear the rattles when you drive? I don't hear anything rattling. It is close by the subframe but I don't hear anything.
Yes up too around 3000 rpm,and idling,i'll try to adjust everything when it get warmer here
I get a little vibrating noise at low RPM sometimes. I am buying a longer reducer coupler to try to make it so that the map sensor doesnt rub on the alternator only one company (HPS) makes them longer than 3 inches. They are fuggin expensive though, duno weather to get the 6 inch or the 4 inch...
Discussion Starter · #8 ·
I dont think a longer coupling would help me its the flange that's angled too much toward the altenator
fits good?Can you actually just buy the cold side pipe?
This is why the depo intercooler is so cheap you get what you pay for TXS FTW
Haha that's exactly what I did a year ago and still working.
I had a shop cut out and move the map flange away from the alternator. Also found the subframe had rubbed almost all the way through the pipe. $60 total to fix.
Discussion Starter · #15 ·
I rather pay 550$ instead of getting raped for an intercooler that is not Worth 1000$++
those are minor issues
1 - 16 of 16 Posts
