1 - 1 of 1 Posts
Vendor
depo racing O2housing & downpipes $100.00
www.deporacing.us $159.90
Depo Racing Genesis 2.0t O2 housing. This is finally done, I have not seen anything close on the market, the cast bellmouth is the best for the extreme turbo side glowing heat. This attaches to the HOT side of the turbo, this portion of the turbo glows red. Cast has no welds that can break after repeated high and low temp changes, this is why cast is best , plus its just has superior flow.
– 2013+ 2.0t
– 3 inch Straight through design (test pipe) eliminates restricted cat section.
– 2 bungs
– Direct bolt on fitment
– Gaskets included.
– 304 stainless steel
– 15 mm thick flange
– Track / Off road use Only
www.deporacing.us $100.00
2008-2012
Depo Racing Genesis 2.0t O2 housing. This is one of the best places to start on the genesis to make power. Its a pain to install so if you buy a poorly made one with bad welds, cheap stainless and flanges you will be replacing when it cracks.
– 2009- 2012 2.0t
– 2 bungs ,one extended with small hole to avoid cel lights – sensor cant get bad smog reading
– Gaskets included.
– 10 mm thick flange
1 - 1 of 1 Posts
