1 - 20 of 40 Posts
www.diodedynamics.com
2013-2016 Hyundai Genesis Coupe Tail as Turn™ +Backup Module
The Diode Dynamics Tail as Turn™ Module + Backup, for the 2013-2016 Hyundai Genesis Coupe! This is a unique mod that was 100% designed by Diode Dynamics in-house, and is manufactured by us right here in St. Louis, Missouri. Made in USA!
The Diode Dynamics' Tail as Turn™ modules will make your nice LED tail light flash as the turn signal as well. With an array of LEDs flashing instead of an amber incandescent bulb, you'll have a unique, modern look!
Then, since your old turn signals are no longer used, you can easily turn them into functional backup lights! You'll drastically increase your visibility.
With the OEM tail light connectors, installation will literally take about 60 seconds, and does not require any wiring at all. I don't think you'll ever find an easier electrical mod! This kit will work with factory or aftermarket tail lights.
The base kit is just $40, which includes a pair of modules with OEM connectors, to convert your LED tail light into the turn signal, with extremely easy installation.
Please note: For ease of installation, our resistor kit will be integrated into each module. This means you will not have to tap any factory wiring to eliminate hyperblinking.
All kits also come with the extra wire and connector to add backup lights where your old turn signals were, but you do need to run LED bulbs, since you're drawing on the factory backup light circuit. At Diode Dynamics, we also offer the highest-quality LED bulbs on the market, backed by a 3-year limited warranty. For the complete Diode setup, you can add a pair of LEDs to your order, or use any 1156-size white LED.
Your order includes:
(2) Tail as Turn Modules with OEM Plug-and-play Connectors
(1) Power wire to add backup lights
(2) Diode Dynamics LED Bulbs (optional, needed to add backup lights)
Remember: at Diode Dynamics, we're here if you need us for support and service, with our award-winning service team. We have been in business for over 8 years. We feature an industry-leading 3-year limited warranty. Something wrong? We ship you the new item with a return label. No waiting around!
Questions? Please feel free to post, PM, call, or email [email protected]
*PM us for the free-shipping code* (U.S. forum members only)
We are an American company, located in St. Louis, Missouri. We are open 9-5 Monday-Friday CST. Give us a call!
Nick C.
Diode Dynamics
(314) 205-3033
Must have mod! Its also super easy to install. The part that takes the longest is actually swapping the bulbs out of the tail light because they have stupid little release tabs that are behind the metal frame of the car so its a little awkward.
I also recommend getting the upgraded LED bulbs to put in the old turn signal slot. I had some cheapy ones I bought off Amazon and they look horrible compared to the DD ones I have in the reverse slot. I want them to be as bright as the sun and blind people when I reverse because i'm tired of almost getting hit when backing out in parking lots because someone has to Instagram their mocha frappa spicea whippa latte with soy and a Splenda while diving.
Tail as Turn™ with XP80 Signals
This is awesome!...instead of wiring the "old" turn signal to reverse light input, I wired it to turn signal feed; I had purchased the XP80 rear signals from Diode Dynamics a few months before releasing this module and really didn’t want to get rid of them. Here is my wiring for the passenger's side:
As you can see in the following video, BOTH the brake light AND rear signal flash in sync when activating a turn signal or hazard lights, but, when the brake is applied (i.e., turning at an intersection is imminent), the brake light and turn signal flash OUT OF sync - a definite attention-getter. I think this is pretty cool. Thanks Diode Dynamics for your superior customer service and making this module simple to install and ultimately adaptable:
Reactions: Diode Dynamics
pm sent
Blue By You
OK, DD guys; here's a heads-up. Perhaps a caution to customers, but probably no one will see this but DD, and that's fine.
You really need to tighten up your order-filling division.
I ordered the turn as tail kit, with added reverse bulbs. The order was sent quickly, but the t-tap connectors to set up the reverse lights, and the adhesive for the resistor, were missing. I immediately emailed you about this. You answered, we discussed the problem, and you issued a RMA. Almost a week later, I received only one t-tap connector and no adhesive. This time I called you about it, and you said you'd send some t-taps and adhesive, and another RMA was issued. A week later, I received not the t-tap, but two quick-splice connectors, as used in the switch-back kits. And again, no adhesive. Now we're running close to three weeks from my original order, with three failures at order completion, so I made do with what I had. I hope the quick-splice connectors are not too big for the smaller gauge wiring. I used some 3M tape I had for trim mounting to secure the resistors. Only time will tell if they'll hold up.
And, my bad, I bought the tail as turn kit, and later the front turn switchback kit, after reading about them in this forum, but forgot to PM you for free shipping each time...
I'm sorry for the terrible experience. That's pretty pathetic, and definitely something we need to correct. We are currently transitioning to a new order fulfillment system with barcode verification of each item, so our staff should be able to do a much better job with special requests like the small items. I appreciate your patience.
"Best thing for bk2 tails!"
The tail as turn mod is the best thing you can do to your tails, extremely easy to install and super quick. All plug and play. And the extra set of reverse lights gives the car a nice look. Pretty bright too. And price isn't even that bad."
-Review by Devendra (Posted on 5/26/16)
Nick C.
Discussion Starter · #18 ·
I am going to pick this up along with the conversion kit for LED lights (license plate, map lights etc). I cannot PM you for discount code because I do not have enough posts. Can you help me out?
You will need to send us a PM to receive the code, or give us a call: (314) 205-3033
Thank you,
Nick C.
1 - 20 of 40 Posts
