To me that seems like overkill but it shouldn't cause any harm, if it seems reasonable to you do it.
Hey Inertia, you seem like a guru on this catch can info. So from what Ive read we need the PCV catch can for the 3.8s. And having 2 is overkill?To me that seems like overkill but it shouldn't cause any harm, if it seems reasonable to you do it.
Have had a single on my PCV side and it's caught more oil than I'd prefer, so it's important. I just pulled off my manifolds and the TB was clean meaning little to no oil has come from the vent side so having one on the vent side is overkill unless you have serious issues, but in that case you need more than a catch can.Hey Inertia, you seem like a guru on this catch can info. So from what Ive read we need the PCV catch can for the 3.8s. And having 2 is overkill?
Finall, the catch cans from MICHI are only for the 2.0T they can be used for the 3.8 i assume? I also will take your advice and only install the PCVside.Have had a single on my PCV side and it's caught more oil than I'd prefer, so it's important. I just pulled off my manifolds and the TB was clean meaning little to no oil has come from the vent side so having one on the vent side is overkill unless you have serious issues, but in that case you need more than a catch can.
catch cans are catch cans, turbo or not. The only diff might be how they are built meaning they expect you to mount them in a certain location so the nipples are pointed in a certain direction, but that may or may not be an issue. I just built my own using a water/oil separator for an air compressor. $20 + $10 for fittings and hose.Finall, the catch cans from MICHI are only for the 2.0T they can be used for the 3.8 i assume? I also will take your advice and only install the PCVside.
As JGowen stated you only need the vent side can if you plan to turbo, or if you track the car due to how much time spent at WOT on the track, there is a member who tracks his NA 3.8 and collects oil in the vent can.Hey Inertia, you seem like a guru on this catch can info. So from what Ive read we need the PCV catch can for the 3.8s. And having 2 is overkill?
The Snoopy cans are design to mount in a specific place in the 2.0T engine bay, and the bracket included and the inlet/outlet placement and angles on the cans are designed with that mounting location in mind, as such they will not work on the 3.8 from an installation standpoint. You can order cans from SM two ways, as JGowen said you can just tell him you have a GC 3.8 and he'll send you a set that have the right inlet and outlet sizes that angle straight ahead on top of each other, or you can pre-plan your install and order cans from him with the inlets and outlets pointed in exactly the right directions and angles for your particular install.Finall, the catch cans from MICHI are only for the 2.0T they can be used for the 3.8 i assume? I also will take your advice and only install the PCVside.
I think Titan meant all things being equal the right can for your application from any supplier will work but you make an excellent point here, for example put a vented can on the 3.8 PCV side and you'll have a serious vacuum leak, not every can design is right for the job.As well, different features are required for different purposes. Whether it's vented or not, baffled or not, and sealed (maintenance-free) or not, make a big difference in suitability and use.
i drain mine at least once a month. be sure to check every week to see what to expect.Your bracket design worked perfectly for my install.
Getting the PCV hose clamp was impossible until I went out and got a cable operated plier, then I could get it under the nipple around the clamp
My drain extension bracket was built reversed from yours so I couldn't mount it quite the same but it is in the same spot if not pointing the same way. I can still get to it though. I ended up having to use a self tapping screw to get it onto the control arm but all is good!
Should serve me well for many years. Who knows when I'll need to drain it, I've had the car for 13 months and the clock just crossed 3900 miles! But a clean motor is a happy motor
Thanks for the writeup!
You want the catch can lower than the pcv so that when you shut off the car any condensation in the hoses drain to the can and not the valve, which can dry and clog the valve.Planning this installation (BK2 3.8) next weekend and can find an answer on this. Can you advise if the altitude of can be of any relevance? too low or too high?
