Hey guys, I’ve seen removing the carbon filter discussed several threads, but I haven’t found a proper write-up, so here goes nothing.
As with any DIY, you the owner assume all responsibility, I’m not liable, etc….
Skill level: 2
Time: 15-20 minutes
Tools needed:
Phillips head screwdriver
Flathead screwdriver (one small and one large if you REALLY want)
Side cutters and/or needle-nose pliers
Begin by unplugging the sensor on the intake tube by sliding the light grey locking mechanism OUT from the tube, then pinching the tab and sliding the sensor off.
Undo the four tabs holding the intake box top to the bottom of the box. There is one on the front, one on each side, and one on the back near the bottom.
The cable for the sensor is attached with a reusable cable tie. To release it, use a small flathead screwdriver to depress the tab under the tail of the tie, and push the tie back through the loop. Set the cable and sensor off to the side.
With your Phillips head screwdriver, loosen the clamp holding the box top to the tube. Back out the screw until the tip is near the end of the bottom half of the clamp. Then wiggle the box top out of the intake tube by pulling towards the front of the car. BE CAREFUL to not damage your factory air filter. Remove it from the box if you feel you can’t remove the box top with the filter in place. The box top should wiggle free of the intake tube without much effort.
With the box top out of the car, we can focus on removing the filter. The carbon filter is held in place by four plastic pins that are basically molded to the filter itself. With your side cutters or needle-nose pliers, carefully pluck the tops off of these pins.
Once you get three of the pins removed, you can wedge a small flathead screwdriver under the edge of the filter and pop it out of place, dislodging the last pin. I say this because one of the pins is in a very narrow channel and is difficult to reach even with needle-nose pliers.
With the filter removed, take your side cutters or pliers and trim any leftover material from the four posts that held the filter in place.
Voila! You no longer have a carbon filter in your filter box!!
I’m hanging on to my filter just in case I need warrantee work on my car. It can be reattached with screws or a small L-bracket inside the box. And I always like to hang on to all the junk I remove from a vehicle as treasures from DIYs
I hope this DIY is helpful. Please feel free to ask questions. I have higher-res photos if anyone has questions. This is pretty straightforward. Engine noise increased marginally (which we all like!) can’t really say much about power increase because the roads are wet. Will be curious to see what MPGs look like going forward.
-Cliff
Skill level: 2
Time: 15-20 minutes
Tools needed:
-Cliff
