I looked all over this forum for a how-to on this topic because I needed to replace my driver’s door handle keyless-entry button because it stopped working. I eventually pieced together part of a plan on how to do this (with information on this forum provided by all you fine folks), and figured out the rest of it on my own. So, now that I’ve done it, I’ll share it with all of you! This is mostly written from the perspective of the driver’s door, but I’d guess that most of this is relevant to the passenger door, too.
Here’s a step-by-step on how to replace an exterior door handle (with or without a keyless-entry button), and, in the process, explain how to completely disassemble a door.
Estimated skill level: 6/10
Disclaimer: Can’t believe I feel obligated to write this... These instructions are meant merely as a guide. This is how it worked for me, and this procedure worked pretty well. If you break your car, I’m not responsible for that.
OK, I’m gonna do this Choose Your Own Adventure-style depending on whether or not you have keyless entry, so look at the relevant sections for your door(s).
I have a 2010 GC with keyless entry and two replacement handles, one from a 2010 and one from a 2011.
START HERE if your car DOES NOT have the keyless entry button:
Tools you’ll need:
-Trim and molding tool set (found these at Harbor Freight: 5 Piece Auto Trim and Molding Tool Set)
-ratchet
-metric socket set (you’ll use the 8mm socket if I remember the size correctly; feel free to correct me if I’m wrong)
-very small Torx/star-bit screwdriver
Step 1: Open the door. Find the small black gasket along the rear door jamb on the door at the same height as the door handle
Step 2: Use your trim puller to pry it out. This reveals a black bolt.
Step 3: Use your 8mm socket and ratchet to undo the bolt (BE VERY CAREFUL not to drop the socket or the bolt down into the door. If you did this, like I did, you’re gonna have to take apart the door; refer to the instructions below and get ready for an hour or so of work)
Step 4: Once the bolt is out, pull to remove the lock portion of the door handle (the rear portion on the passenger side)
Step 5: Grab the handle and pull firmly toward the rear of the car; the handle should pop backwards and off the car. Fish it out of the hole it’s in.
For the replacement handle, if you want to change out the colored part of the handle to reuse your old handle’s colored piece, go to the section below called To reuse your old handle’s colored piece
Step 6: Put the new handle in by doing the reverse of the procedure that you used to yank it out
Skip below to the section called Handle Reinstallation for reassembly instructions
START HERE if you car DOES have a keyless entry button:
Tools you’ll need:
-All the tools listed above, plus...
-philips screwdriver
-metric socket set (8mm and 10 mm and maybe another one if I remember the sizes correctly)
-patience
-a few hours free if this is your first time
Snoopy’s video does a great job explaining how to remove the interior door panel, so here’s a link to it:
https://www.youtube.com/watch?v=18vaa7dWaV8
Brief summary of video, if you can’t watch it:
Step 2: Remove rubber insert in interior door armrest bin to get at screw underneath, then remove screw
Step 3: Pop out panel behind interior door handle and remove screw behind it
Step 4: Grab and pull on the small triangle of plastic at the mirror’s attachment point; it’ll come right off. Grab door panel, lift up and pull gently out
Step 5: Disconnect all wires by pushing on releases and pulling
Step 7: Set aside door panel
Now, to remove the silver panel with the window motor in the door:
Step 8: Gently pull off the interior rubber seal next to the window at the top of the door panel. Set aside.
Step 9: Pop open the upper rubber gaskets in the silver door panel. These reveal the bolts that hold the window glass.
Step 10: Unscrew bolts slowly, glass will drop slightly when you do this. Just unscrew the front bolt enough to loosen the glass. I’ll explain why later.
Step 11: Gently lift the window glass up and out of the door, keeping in mind that the rear of the glass has a plastic bracket attached to it. Leave that bracket in place and set aside the glass (preferably lay it down on the ground on something soft. I laid it down on top of my door panel that I set aside)
Step 12: Remove all 10 bolts around the outside edge of the silver panel
Step 13: Pull gently to unstick the seal around the silver panel from the door itself.
Step 14: Once unstuck, lift the door panel up at the front end and angle that end out. Push the panel forward gently to release the rear of the panel. Wires are still attached to the panel, so set it vertically along the seat between the door frame to get it out of the way.
Step 15: Bend over and look up into the door at the rear end to find the plug for the exterior door handle’s keyless entry button. Unplug the plug.
To remove the exterior door handle of the car:
Step 16: Find the small black gasket along the rear door jamb on the door at the same height as the door handle
Step 17: Use your trim puller to pry it out. This reveals a black bolt.
Step 18: Use your 8mm socket and ratchet to undo the bolt
Step 19: Once the bolt is out, pull gently (then harder if it won’t budge) to remove the lock portion of the door handle (the rear portion on the passenger side)
Step 20: Grab the handle and pull firmly toward the rear of the car; the handle should pop backwards and off the car.
Step 21: Gently pull the wire out of the door (be mindful that the black plastic gasket may come with it. You can either reuse this gasket or use the one from your replacement door handle. Your choice.)
This depends on 2010 or 2011-and-beyond handle (do this to both your old and replacement handles):
2010 handle:
Step 1: Unscrew the small Torx/star-bit screw at the rear end of the handle.
Step 2: Gently pry the colored piece down and off the black plastic piece with your fingers, starting from the rear end of the handle. A flathead screwdriver can be helpful to get it started, but be careful not to scratch the colored handle.
Step 3: Once the rear end has come off, gently pry the front end off too, but take care to not flex the colored portion too much because you don’t want to snap it in half
2011 handle:
Pretty much the same procedure as above (including preventing the snapping-in-half, part), except that you have to remove a screw that holds the front part of the handle on. It’s in the back of the handle towards the front of the car (the part that connects to the door) and its a small silver Philips head. This handle seems to be more brittle than the 2010’s handle (ask me how I know!), so be EXTREMELY FREAKIN’ CAREFUL when prying off the colored part of that handle because it can snap in half (ask me how I know!)
Next step for either year handle:
Step 4: Now, take your colored portion and snap it onto the replacement black plastic handle, starting from the front end (keyless-entry: make sure the wires are sitting as they should be inside the handle)
Step 5: Screw in the small Torx/star bit into the rear of the handle to hold the colored portion to the black plastic handle.
Step 20 million (nah, Step 22): Put the handle back into the hole in the same fashion you pulled it out. Insert the front first, making sure it’s sitting in there correctly, then push the rear down into the hole until you hear a thunk or a snap, ensuring the handle has linked up with the metal door-release mechanism arm inside the door. Pull the handle like you’re getting into the car to make sure it works.
Step, um, 23: Take your lock and push it into its slot slowly, ensuring the flattened end of the rod mates up with the unlock mechanism receiver again (mine was green plastic).
Step 24: Put the bolt that holds in the lock back into the hole in the door jamb and tighten it snug, but don’t kill the bolt, it could strip out the plastic threads in the plastic housing)
Step 25: Reinsert the round black plastic gasket.
Step 25.5 (for keyless entry): Go into the interior side of the door and plug in the button’s wire.
Make sure it works by putting the key fob within range of the door handle and push the button. If your car makes its irritated long beeeeeeep, it works! SUCCESS!
Door Panel Reinstallation
Step 26: Take silver panel and place it back into the door, making sure the front and rear silver posts sit into their holes properly. Insert all the bolts around the outside and tighten, but don’t kill the bolts, don’t wanna strip the threads out.
Step 27: Reinsert window glass. Lower it into the channel, ensuring that it goes far enough forward to sit inside the front rubber gasket aft of the rearview mirror mount.
Step 28: Remember how I said to leave the front window’s bolt in? Now snug up the bolt and tighten it just lightly, but don’t tighten just yet, there’s a lot of adjusting and aligning of the glass in your future.
Step 29: Look into the bolt hole for the rear of the glass. Align the hole in the center and lift the glass a little, then insert the bolt and tighten, and tighten the front bolt too, but be gentle to ensure you don’t crack the glass.
Step 30: Close the door and check the window for alignment at the top and rear with the weather stripping. I just copied the alignment from my passenger-side window. This takes a bunch of checking and adjusting and tightening, so take your time and be as anal retentive or as lax as you like, but just make sure its a good, tight seal with the weather stripping, otherwise water might get in.
Step 31: Put back the interior strip of weather stripping, ensuring the felt cloth piece faces the window.
Step 32: Bring over the interior door panel and replug all the wires. Check everything to make sure it works. Then, reattach the panel by hanging the top of the panel on the door first, then pressing all the pop fasteners back into place.
Step 33: Put a screw into its spot behind the interior door handle and put back the plastic panel over it. Put the other screw back into its spot in the door armrest bin and put back the rubber liner.
Step 34: Press on and reattach the triangle of plastic near the mirror mount.
Step 35: DONE! WHOO!
BONUS IMAGES!
2010 door handle, keyless, disassembled
2011 door handle, keyless, disassembled
Mirror bolts and wire loom
Wire looms at the front of the door
Inside the door looking forward at the rear of the door woofer
Inside the door looking rearward at the lower part of the door
Another view of the front inside of the door speaker woofer and wiring
Another view of the rear of the door woofer
The rear of the silver panel, with window raise/lower mechanism
Front window support on up/down track
Front window support, up close
Front window support, up close, taken apart
Raaz
I was wondering if it was required to replace both the passenger and driver side door handle for keyless entry systems. Dealer states i am required to replace both for them to work correctly. So im just curious before i delve into the junkyard to try to find a door handle if i should even waste my time.
Discussion Starter #3 (Edited)
Nope, the dealer is full of **it. I only replaced my driver-door handle by itself and I’ve been driving my car every day since I did the repair, and it’s good as new; no problems!
:laugh:
Raaz
Yea I pretty much figured the dealer was just full of it trying to charge me 191 dollars for a new set... Thanks for the reply I will be doing this after I finish my tablet install which I will be doing on Sunday. Can't wait to put it in my genny
Very nice writeup.
We are just past our 5 year non-drivetrain warranty expiration and the passenger side exterior door switch is dead (goes in, never springs up). Would rather just replace the switch than the whole handle.
This would be the third exterior door handle on the car. I guess the Koreans have door handles mastered like the English have oil sealing mastered!
We have the keyless entry. I've search the top 3 Google results for Hyundai OEM parts (all dealers with shitty websites) and couldnt find anything useful or concrete.
Is the switch available solo? Part number? Source? Expected price?
Anyone have identifying info for the handle with the switch installed? The line drawings on the aforementioned dealer websites suggest the switch doesnt come with the exterior handle.
If not does anyone know the correct part number or identifier (as the dealer websites obfuscate the OEM part numbers to prevent shopping) for the handle with the switch installed?
If not does anyone know the specs on the switch? Soldering three wires is cake. I'm not sure why there would be three wires though.
Thanks,
Jim
Thank you very much for posting this DIY! I followed it without any problems to replace the smart key (keyless) handle on my passenger side door, and to also swap the painted portion of the handle from my old handle to the new one (that wasn't painted). (2010 KDM Gen Coupe)
I would like to add two things to this great write up:
1) The painted cover of the handle has small tabs in 6 places. You can see some of them in the pictures, but not clearly IMHO. They are in 3 positions on the thin part of the handle, directly across from each other in pairs; close to the rear (fat part of the handle the comes out the most when pulled), in the middle, and close to the front (part of the handle that pivots when pulled). I used a couple very thin slotted screwdriver bits as wedges as I worked my way "down" the handle as the OP suggested. Patience is certainly the key...
2) One might want to use a paint pen and mark the position of the two bolts holding the window in place before removing them. This would help save time during (or possibly even eliminate) the window adjustment phase of this DIY.
