For 2.0L people who are considering the Jun B.L oil catch can, here is a quick guide that should help you with the install process.
Hoses are routed as such...
After you run the hoses, cut off the excess and use small zip ties to tidy up the engine bay. Just make sure to keep the hoses away from moving parts and anything that would get overly hot.
For example, you can see above that I have a hose running on top of the intercooler pipe on the left side (the one going down to the intake). I did this because the hose was otherwise resting on the manifold cover--which gets extremely hot. When I have a minute, I'm going to re-route this under the pipe simply because it would look better, but this time I plan to zip tie it to the bracket that's just to the right of the Injen logo. (Tough to see in the pic due to the lighting).
As for the remainder, it's very simple.
The only part that is not included from Jun B.L is shown below in the pink highlight. I'd recommend getting a 1/2" vacuum hose cap from your local auto part store for this. If you are in a pinch, you can always just cut the OEM hose that was in this location and clamp a bolt inside it. This is only a temporary solution on my car because I haven't gotten the vacuum cap yet (my car is rarely driven), but you technically could get away with it if you really wanted to. I just don't think it looks 100% professional.
One item to note is that my Coupe has an auto transmission, so I only have one hose going to the intake. (Shown above in the blue highlights). For those of you with a manual tranny, you'll have two hoses going to the intake--one will be from the Jun B.L kit and the other will be coming from the back of the engine. Either way, this shouldn't be confusing because the Jun kit only effects the hose coming from the side of the engine where the reducer is utilized (shown above in green highlight). For manual tranny setups, there will always be two--but the second hose is not effected by the Jun catch can.
x.jpg)
x.jpg)
