Yes though you will not get the whole two bottles in. I would consider doing a flush too. So 4 bottles for that.32oz bottles, so I need 2 of those?
Logic dictates if you hit something and not fluid is leaking, there is physical damage done that needs to be repaired. Changing the fluid and filter to try and remedy that is like saying I broke my leg, should I get some new blood to fix it?I need you guy helps, My Genesis Coupe 3.8 Track 2011 recently hit something and my transmission fluid is leaking, and when I put into gear it won't run. Do I change the transmission fluid filter and which type should I buy ? and which transmission fluid would fit my gen ? If you guy could help me please, I really appreciated. Thank You
Logic dictates if you hit something and now fluid is leaking, there is physical damage done that needs to be repaired. Changing the fluid and filter to try and remedy that is like saying I broke my leg, should I get some new blood to fix it?I need you guy helps, My Genesis Coupe 3.8 Track 2011 recently hit something and my transmission fluid is leaking, and when I put into gear it won't run. Do I change the transmission fluid filter and which type should I buy ? and which transmission fluid would fit my gen ? If you guy could help me please, I really appreciated. Thank You
So on the 2010 2.0 T track manual transmission the top filler Bolt is a 17 millimeter and the drain plug is a 24 mm? I have looked through three of my tool boxes and for the life of me I cannot find a 24 mm it seems like they stopped at 22 lolJust did this today and the Tranny filler plug is 17mm the rest are all 24mm just thought id let ya know.
PLUG - MAGNET | 0081017121 | $3.84 |
