1 - 1 of 1 Posts
Here's a quick DIY of some wheel painting (rattle can).
I did this awhile ago and thought i share...
Color: satin black (NOT matte or flat black). there's a slight difference.
19" 4 wheels, 3 different colored wheels (only 2 colors are shown)
step 1: mask wheels where you don't want paint on (green or blue 3M-- very time consuming)
step 2: sand down wheels with 400 grit. 300 or 200 will work as well. make sure all clear coat is stripped down.
step 3: clean wheel
step 4: you can spray primer (i chose to skip this step)
step 5: i went ahead and spray down the satin black spray.
i use the roll bar satin black spray paint. i bought 4 cans. roughly 1 can per wheel. 2-3 coats of paint. 5-10 min in between each coat.
i also took the time and painted the inside and outside of wheel barrel as well.
step 7: let dry (i left it overnight)
step 8: take masking tape off
step 9: done!
here's a final result:
on my other car:
thanks for looking!
next up. how to clean your dull headlights
1 - 1 of 1 Posts
