1 - 15 of 15 Posts
Hello, I own a 2010 genesis coupe. It does not have keyless entry. So I had a few radio lights that were burn.. and decided to check all the fuses from the interior fuse box. None were blown. Then right after that. I can't lock either from the remote or the inside button. Plus the auto lock wont work either. The one noticable thing is when I press the unlock button on the remote, the lights flashes but nothing else. Ps : my power windows work. Thanks for the help:|
There is a 10a fuse that powers the door lock relays. It's in the interior fuse box labeled DR Lock.
On the back of the fuse cover, none is labeled "door lock" ... I checked on other genesis's labels and where their dock lock fuse is, mine is empty...
Mine does not have a door lock fuse... I says in the owner's manual, but when I check on the graph behind the fuse box cover, its not there.
You are going to have to trace the 12v wiring back from the door lock solenoid. It will be difficult. If I have time today I will look for the door lock relays.
1 - 15 of 15 Posts
