I have posted about my rear toe rod bolts being seized to a degree I have never seen. Using a torch, penetrating fluid, 50/50 ATF and acetone, a hammer, and an air hammer have all failed to knock the eccentric bolt out from the toe arm. My final solution is to chop the bolt off with my angle grinder. I am going to be replacing the stock rear toe arms with PBM adjustable toe arms.
Here is my question, since the sole purpose for eccentric bolts are to slightly pull the arm forward or back for slight toe adjustments, since the new arms themselves are adjustable on the actual arm, replacing the eccentric bolts with regular bolts should be ok because I don't need the adjustments from an eccentric bolt. I just wanted to double check my logic of replacing the eccentric bolt with a regular bolt for the aftermarket arms. Here is a picture of the seized bolt. I will find a washer that is the same diameter of the eccentric bolt head so that it fits in that notch like the stock bolt.
