Engine cylinder head
239 Views 6 Replies 2 Participants Last post by  Nathan M.
So my original head says 8-2.0L #3 and has circle holes and my one I just got says 8-2.0L #1 and has square holes does that matter
Automotive tire Motor vehicle Rim Bicycle part Automotive wheel system
Motor vehicle Automotive tire Gas Automotive exterior Auto part
1 - 7 of 7 Posts
Looks like the enlarged the holes. Those must be oil drain holes?
ok, so basically I’m just wondering if it would still work or if it will mess something up when I put the engine back together
What does the front center of the head look like between the cams? Is there a rubber tube to direct oil to the front of the timing cover?
Like this
Your pic the back of the head?
Automotive tire Motor vehicle Blue Road surface Door
Like this
Bicycle part Rim Automotive tire Gas Auto part
so there’s this rubber thing on the timing cover and all the pictures have been the front of the head
So that's for the intake cam solenoid valve? As long as your mating piece lines up I would say the bigger the holes the better.
Reactions: 1
This is what it looks like, and what do you mean mating piece
Automotive tire Bicycle part Tire Wood Wheel
1 - 7 of 7 Posts
