For the 2L.
The bracket should be about 7" tall. That would give enough wiggle room for the holes to drill and clear the coil cover but still be below the strut bar. Looks like it's 26&1/4" from the strut bar mounting stud to the bracket.
The engine lift hook also has a heat shield for the exhaust cam sensor connector. That will limit the width at the bolt hole on the bottom. I'm using a 1x1x1/8" angle iron. The bottom mounting hole needs to be just slightly to the outside so the heat shield fits without any interference. I drilled mine on center and it will slightly deform the heat shield when tightening down the bolt.
