Mike
Ok so last week I noticed my car was shaking/vibrating but I brushed it off. Now I'm starting to give it more attention and my car shakes only when I'm at a complete stop but when I push on the gas it stops, and also I noticed my hood shakes also. Any ideas on what it can be?
Check your engine/transmission mounts
No idea, I have a 3.8 manual.
Genesisat_18
basically, yeah sounds like trans or engine mounts unless your car is missing firing at idle. But, more than likely it's a mount. If you're mechanically inclined I suggest doing it yourself. Although engine and trans mounts themselves aren't expensive the cost of labor is.
Mine does this when the AC compressor is engaged.
There are two mounts one on each side in the center of the motor attached to the subframe.
