horsepower/tq gains with a fmic?
mod list:
tbe
injen ic pipes
synapse intake
( tune to come)
now if i add in a front mount what will the increase in power be?
mod list:
tbe
injen ic pipes
synapse intake
( tune to come)
intercooler is mostly for efficiency, but there has been gains when using hard piping rather than the OEM, with a tune maybe around 5-10hp. But its a needed mod for the stock turbo because of heat soaking. But your not going to see much of a difference before the tune, and i suggest injectors before the tune...
I gained 10whp & 14ish of tq with my cxracing fmic. Funny thing is hp # kept going up as i did more runs. 1st run was 242, 2nd run was 244, 3rd and 4th runs were 245 then called it a night
For the IC pipes; its not that they add more HP, its more that the stock ones takes some away. The rubber couplers do expand a bit under pressure :p
Hammer lane Hero
As was just said, it's one of those mods that frees up HP that was already there, doesn't actually add anything.
Just curious, but given the climate you live in, did the temp/humidity go down progressively through the night? that could explain the numbers, no?
