Anybody?
X2. Boost gauge is a must for anyone modifying a turbocharged car. You don't necesarrily have to leave it in all the time, but you have to be able to check your boost levels somehow.You need a boost gauge...........
What issues were you having? What should I be looking for? What problems would I notice if I was using a spring that was too stiff and also one that was too week?X2. Boost gauge is a must for anyone modifying a turbocharged car. You don't necesarrily have to leave it in all the time, but you have to be able to check your boost levels somehow.
I've got the Forge BOV and use the yellow spring with BRs stage 3 tune, no issues for me. I was using the 5-18psi (green?) spring with one spacer for a while too, figured the 19-23psi spring was a better fit, never had issue with the other spring either. It shipped with the 25-30psi spring in it and I was having issues with that one.
