1 - 12 of 12 Posts
I just installed a forge bov on my 2013 gen bk2. It came with three springs. I thought that I had to use the yellow spring because of it used for the the bk2 but I couldn't get it to release at high rpm's or at all. I swapped springs and used the green which I thought was for the bk1 for less psi and it works now. Does anyone else use the yellow spring that doesn't have a tune?
Sent from my SAMSUNG-SM-G925A using Tapatalk
What's your boost peak at?
15psi. At least that's what the factory gauge says. I took it for a spin and it reaches peak boost at 15psi on WOT but it starts tapering off.
Green is 5-15psi. Yellow is 15-23psi. You're right on the cusp but yellow needs a bit more pressure to open. Enough that would open up to 23lbs.
I see the reason to use the green spring but it seems like it doesn't hold peak boost for very long. It is a major improvement over the factory bov. Thanks for your input.
I have a Forge BOV on my 10 Mazda CX7 and in addition to the springs it came with some diffrent thickness washers to go behind the spring to let you further fine tune it. I used yellow with the thin washer.
I have a BK2 2.0T and I used the yellow spring before and after my tune with no issues. Stock BK2 should be able to boost up to 20psi despite the gauge only showing 15. I've had no issues with my SFR 1.5 tune and the yellow spring.
One of the next things I'm planning to change out are the gauges to more useful ones. I'm definitely curious as to what PSI I'm actually hitting.
Discussion Starter · #8 ·
Yeah I couldn't use the yellow spring. I'm the 2nd owner of my car and the previous owner installed a greddy front mount core. I'm kinda guessing the car is leaking boost pressure.
I use a yellow spring and a shim. See 22psi peak boost and around 22"Hg of vacuum at idle. It does vent at idle sometimes.
Make sure you service the Forge BOV at least once a year, probably twice is better.
They sell a rebuild kit with new piston and orings and some grease. FMDVSK-HGA
So at stock I should be using the yellow spring?
1 - 12 of 12 Posts
