1 - 5 of 5 Posts
Hi guys,
Does any body know for sure if there is any difference between BK1 and BK2 front struts ? I've looked thru some catalogs and found
for BK1 :
EX546512M100, EX546512M101
EX546512M200, EX546512M201
EX546512M250, EX546512M251
EX546512M300, EX546512M301
for BK2:
EX546512M500
EX546512M600
EX546512M650
EX546512M700
And I wonder if BK1 strut will fit my BK2? cause some why they are trice cheaper.
Not for sure. But www.rockauto.com shows the Bilstein aftermarket struts and shocks as fitting all years. B6 is for stock ride height, B8 is for a lowered suspension.
BILSTEIN 35196389
B6 Performance; For Stock Ride Height
Front; 2.0T Model; 2.0T Premium; 2.0T R-Spec; 2.0T Track; Requires 2011 Sway Bar End Links
$206.79
Increased Handling/Performance
BILSTEIN 35197348
B8 Performance Plus; For Adjusted Suspension
$212.79
BILSTEIN 24196390
Rear
$107.79
BILSTEIN 24193702
Rear
$111.79
The BK2 came with softer suspension, so I assume the different part numbers are because the struts have a softer compression rate.
Other than that, the mounting previsions/dimensions for the struts are the same.
1 - 5 of 5 Posts
