61 - 65 of 65 Posts
· wannabe guru
Discussion Starter · #61 ·
I'm definitely going to do the relay since I'm pretty sure that's what killed my first DW pump
· Registered
700's are pretty much the max for the OE fuel pump unless you drop the pressure, which is possible with a boost referenced FPR kit.
I'll actually be installing that unnamed companies kit.
Hey Snoopy, so i read the DIY relay thread and this thread, i have a stage 2 BTR tune for my 2.0 Rspec, and i installed a stage two clutch and flywheel and a couple spacers for the heck of it. but when i hit about 6700 rpm it starts feeling like it's gasping. I can only assume it's the additional air and i was thinking of upgrading the fuel pump and getting an FPR. But then i read about the voltage drop and how one of the guys on the thread went back to the "return-less" system after doing the relay mod and it fixed the issue. i'd really like your opinion...upgrade the fuel pump and get an adjustable or boost referenced FPR, which if i do, i'm guessing it's not plug and play and i'd have to do a return system, if getting something like this guy here or would i?:
http://www.gencoupe.com/3-8-v6-disc...-fuel-system-upgrades-pump-fpr-pic-heavy.html
or just do the relay mod and pray for better fuel flow to the injectors?
Thank you in advance
· Premium Member
The one i'm selling is almost plug and play, but i suggest doing the relay as well.
http://www.gencoupe.com/private-classifieds-engine/626586-fuel-return-line-pump-90-plug-play.html
· Registered
Any idea which relay is best replacement for the stock one? If the stock pump runs 10-20amps max I'm guessing I wouldn't need more than a 25? It's cool that AMS tested the OEM pump to get 185lph at 55psi. If you compare it to the DW200 or DW300 you can see they flow more at those pressures. I doubt the stock pump hits 180lph at higher pressures than that but who knows how it's designed:/ Either way for pump gas you might get a bit more flow without going to a huge pump that requires 12 gauge wiring for 15amps at idle.
61 - 65 of 65 Posts
