1 - 3 of 3 Posts
Yo, it's been a while since I've been on here.
I was on my way home from buying brake pads when the gasket between my turbo and O2 housing decided to pop out. Apparently, I'm missing two bolts that hold the O2 housing and turbo together. I think the previous owner who installed the O2 housing put the bolts back in backward because the one bolt that remains is in backward. Lol.
Anyway, I've attached a few images of what I'm talking about as well as the diagram for the assembly. I've circled the bolts that I need help with. Does anybody know where I could buy replacement bolts or just the size of those bolts so I can pick some up from Ace?
Product Rectangle Organism Font Screenshot
Helmet Bag Automotive tire Motor vehicle Personal protective equipment
Automotive tire Hood Motor vehicle Tread Bumper
Automotive tire Tread Tire Grey Stairs
OE turbo bolts strip easy. Two go all the way through and one does not IIRC. The one that does not can be drilled out so you can use longer bolts and tighten with a nut. Or use the OE ones if they aren't stripped.
Severed member
Gencoupestore.com.com is a great place to look. Write Tim and ask if he still has his 3 bolt brass set. I still have 3 extras I carry in my trunk just in case.
Tim is awesome and is a great resource for all things Gen coupe!
1 - 3 of 3 Posts
