1 - 1 of 1 Posts
Hello,
I have an unusual problem with my Genesis. Namely, it happens to me, not so often, but it happens that while driving, when I push the gas pedal to the floor I feel that the car has no power, I can't hear the turbo. But when I turn off the engine, start it up the turbo works. But when the problem comes back, you have to turn off the engine again and the problem stops. I don't have any check engine. The car was hooked up to the computer and the only error it gave was a brake pedal error. I pulled the sensor out from under the brake pedal, measured the sensor with a meter, it is working fine.
Do any of you have any idea what is wrong with my Genesis?
Has anyone had a similar problem?
Greetings!
1 - 1 of 1 Posts
