1 - 20 of 105 Posts
www.diodedynamics.com
Looking to add a little color to your Genesis' interior? Diode Dynamics' RGBW Multicolor Footwell LED kits are the way to do it! By adding Diode Dynamics' LED strips under your dash, you can add RGBW color-changing ability to your Hyundai Genesis' footwell area.
This kit is not just RGB, it is RGBW! That means there is an extra integrated LED chip that is specifically white in color, right next to the standard red, green, and blue LEDs. By using an RGBW controller, you can activate and control the white chip independently of the colors. This provides a much more uniform, pure, and bright white color than the traditional method of combining all RGB signals.
Our Bluetooth Controller will allow you to choose any color under the sun, including True White, directly from your phone! Our mobile app includes a wide variety of features including strobe and fade effects, preset colors, Camera Match, Music Sync, and much more. Our controller will also allow you to adjust the brightness of the LED strips. Any time you power up your strips, they will default to the last color that was previously selected.
These LED strips in this kit are highly flexible and waterproof. They feature high-density LED chips for brighter output and barrel-style M8 connectors for a secure connection.
Included in the 2-Piece Kit:
  • Two (2) 50cm RGBW SMD30 Strips
  • One (1) wiring harness (4-foot)
  • Two (2) quick splices
  • One (1) red LED toggle switch
  • One (1) DC-to-DT adapter
  • Four (4) zip-ties
  • One (1) 3M outdoor adhesive pad
Included in the 4-Piece Kit:
  • Four (4) 50cm RGBW SMD30 Strips
  • Eight (8) zip-ties
  • Two (2) 3M outdoor adhesive pads
  • Two (2) RGBW M8 extension wires
The 2-piece kit includes everything you need to install LED strips in the front footwell area on both the driver and passenger side of your vehicle. The 4-piece kit includes everything you need to install LED strips in the front and rear footwell areas on both the driver and passenger side of your vehicle. This kit is very universal in nature and can be tapped into any 12V power source that you would like when installing.
Any questions email us at [email protected]
PM us for the free-shipping code (U.S. forum members only)
Thanks!
Collin O
Discussion Starter · #8 ·
Cool! This is what I've been looking for. DD, is there enough wire in the kit to pull power from the over head dome light in the GC? And will the LEDs dim/fade with the dome lights? thx
The kit is designed to be installed with the cigarette lighter power. The kit requires 12V + and - so you can wire it in any configuration you would like, however, we do not recommend adding extra load to the dome light dimmer switch as it is a somewhat fragile component in most vehicles.
Thanks!
Paul
Got mine installed.
Phone pic.
Only thing i had problems with was the switch. I drilled a 3/4 hole, but it wasn't big enough i had to file it out to make it fit. I put it here:
looks pretty stock especially with the blue light.
Thanks!
Paul
So I can install, and just plug it into the cigarette lighter power, or splice into that power?
Shipping was 10 to canada :p made my girlfriend order me a pair for my birthday on Tuesday and my new gen.. Whenever i get it. How long does ahippibg usually take to saskatchewan?
Sent from my SGH-I747M using AutoGuide.Com Free App
1 - 20 of 105 Posts
