if u want to have good performance yes
Can u explain? I have never bought wheels before so I don't really know where to start.
look wise, it will look a little weird because a full square set-up will have the front wheels poking out a little more then the back compared to OEM fitment.Ok thanks for the info. I really don't race my at around too much. I decided to go with a 8" wide wheel all around. I got a set of Motegi racing MR118. I really hope they work out for me. Thanks again for the help.
:wtc:I decided to go with a 8" wide wheel all around.
:werd::wtc:
OK, after that statement I had to do a little word definition searching. Wiki says that staggered tires are when the tires are different widths. They don't mention diameters. I always assumed it was the other way. After more searching the more general consensus is whenever either the diameter or the width is different.I am sorry I made u sad slider. I didn't have to many option. I got them with my sears card. I wanted black and there was only 3 I even liked. And the mr118 were the only ones I could really afford. And they only came in a 8" width. The recomend tire sizes are the same as the stock tires. Like I said I don't auto-x or drive to hard or the street. So I hope they work. Since the fronts will be more flush then the rears could I just get spacers for the rear to still give it the staggered look? And about the traction controll system I have read other posts about it and from what I have read the staggered wheel size is not what makes the TCS come on.
+1....Crash course:
Having tires in the rear in a staggered setup helps make oversteer more controllable and having more grip in the rear than in the front allows your front tires to break traction before your rear tires (this is without any throttle input and assuming the tires match in compound and grip). Staggered setup also allows the throttle input to be more of a decisive tool when cornering, since the rear has the higher amount of grip; you can use it mid corner to try and hit your exit line. you'll notice with the shi**y stock tires this is mute point because trying to get grip mid corner high RPM is a joke, you just break traction and the ass comes out. <where the variables start to come in (road condition, tire compound, tire condition, etc..)
Besides that; Say you enter a turn too fast, your front tires will break traction first causing the car to understeer (no throttle input) - this is safer and easier to make corrections to. A late brake will cause the weight to transfer to the front, increasing grip to the front wheels allowing you to correct (and possibly causing oversteer if you smash the throttle)
As for the wheels go, having a matched wheel to the tire width can change handling dynamics... a streched tire (to a point) can stiffen the sidewall and increase turn in feel but decrease maximum contact patch (this is why drifters us stretch because very rarely do they need straight line grip and the smaller contact patch is more responsive to throttle input).... a squared up tire will have a mix of both straight line grip and cornering fee.. an oversized tire will have decreased cornering feel but can greatly increase straight line grip.
hope that makes sense... there are a lot of variables but that is the basic functional reasoning behind RWD staggered setup I have learned from going to Auto-x skills days and such.
+1....sounds pretty accurateOK, after that statement I had to do a little word definition searching. Wiki says that staggered tires are when the tires are different widths. They don't mention diameters. I always assumed it was the other way. After more searching the more general consensus is whenever either the diameter or the width is different.
I believe the TCS is set to having around a 3/4" difference between the front and rears with the rears being the bigger. If you go with the same diameter front and rear you will more easily trigger the TCS as it appears that the rears are spinning faster then they should because the rears, with there larger rolling circumference, should actually be spinning slower then the fronts at a set speed.
Other then the tires spinning more easily, if they are narrower with less grip, the TCS shouldn't be effected by tire width, only by the how fast the fronts are rotating as compared to the rears. The TCS actually monitors all four tires but for tire size we are only talking about front to rear.
Anyone else want to chime in?
+1yup your right... but when you have a wider tire like stock in the rear...
225/40 front 245/40 rear.. the rear ends up being taller because the sidewall height will be 40% of 225 and 40% of 245 so the rolling diameter (assuming 19" stocks) of the rear ends up being 16mm larger than the front
cliffs notes: tire width directly affects rolling diameter
It would still be considered staggered, but I wouldn't do it. It is possible & some cars like the Plymouth Prowler came that way, but you may have to do some investigating to confirm it won't interfere with your traction control.What if I want to run a 19" wheel in the front and a 20" wheel in the back? Would that still be considered staggered? Is it possible? Anyone else running it?
The TCS doesn't care what the Wheel size is. It only recognizes the overall diameter of the tires. Most will hate on this idea, but I actually plan to do it, myself. Every time I see a Coupe with 19's front and rear, the rear look smaller than the front to me. Probably because of the very rakish wedge shape of our car. I could only find one picture of a Coupe running 19f and 20r:What if I want to run a 19" wheel in the front and a 20" wheel in the back? Would that still be considered staggered? Is it possible? Anyone else running it?
It's ok man.I am sorry I made u sad slider. I didn't have to many option.
