1 - 8 of 8 Posts
Hey everyone!
I just got my Genny Dyno Tuned with the following mods:
Full ISR Turbo-back exhaust
Forge BOV
AEM Water / Meth Kit
CC Stage 2 Clutch
Depo Racing Intercooler with custom piping
K&N Short Ram Intake
Haltech ECU
DW 1000cc injectors
320lph Fuel Pump
Garret Gen 2 GTX3071R with an 0.63 A/R T3 Housing
Frankenstein MXP Manifold with T3 flange
Turbosmart 38mm External Wastegate with 14 PSI spring w/ Custom Dump Pipe
Mac 3 Port EBC
Oil Catch Can
Some Pictures of the actual setup:
76193
76194
I used the Haltech to get a "low boost" setup and a higher boost setup, so results were this:
76195
Blue one is for 14 PSI and Red one is for 22 PSI
Redline was increased only to 7000 RPM as the engine is still stock on my BK1.
Things to consider: Highest Octane fuel here is 91, so using Meth is a must when tuning.
They also did a pretty cool video (Ignore the change of wheels during the video lol)
I would like to compare similar setups if possible to see if numbers are similar.
Hopefully the engine holds up for a bit of time before it goes boom. Then I will go ahead and build it and see how much more power I can get from this setup :D
My god that build sounds damn expensive for 350 rwhp. I hope you love it lol.
I know it would cost about 15 grand Canadian to get that done on a bk2 correctly.... Which is why i ran from that and kept mine at 300 with simple bolt ons and a tune.
Looks pretty good. Is that exhaust manifold a T3 only? I love the wrap and cold side piping. Looks super clean:)
This manifold has actually the OEM style flange (circular) but because I do not live in the US it made more sense to just modify it to a T3 flange instead of buying another manifold.
BTR Tomei MX7960. 52mm inducer vs the Garrett 54. Turbines are 1mm different. 20psi 91 octane turbo back exhaust. Maxes out at 400 if meth is used.
Pretty much similar power, tho the Garret can be pushed for more, I would think that the Tomei can as well but idk.
Is that on a BK2? Idk if the better internals make it flow better (I would guess so).
Oh yeah it was, but it can be pushed for more, right now the only limitation is the stock block basically.
Oh yeah, you can get a BK2 on those numbers for way less. The BK1 needs the turbo upgrade, so I decided to go all the way lol.
i noticed this is 3 months ago. how has the engine held up ? i wanna get 300 to the wheels on mine or even 350 but ive seen nothing but stock internals being ass. thanks
Discussion Starter #8
Hey!
It´s been holding up pretty well. It was actually tuned with the big turbo since december last year, with constant hard pulls and even a time trial event.
I first started with the same turbo but internal wastegate (ATP), which was okay but kept giving me boost issues because it was tuned at 19psi (wastegate had a 10psi spring). Then I switched to the external wastegate and T3 flange.
After the mentioned Time Trial event however the MXP manifold cracked (I would recommend to stay away from it), so I ended up getting a custom made manifold locally (with better materials), and it has been good since.
76568
1 - 8 of 8 Posts
