1 - 5 of 5 Posts
So i have a track bk2 , my door was hit couldn’t find a replacement so i got a bk1 door my key fob doesn’t lock the door and my window won’t go down unless you open the door any suggestions
The door switch is wired different between BK1 and 2. BK1 door switch is a grounded input directly to the BCM. BK2 it;s a grounded input to the IPS module (instrument cluster) then over the CAN bus to the BCM.
The Saftey ECU is part of the window motor connector.
75377
75378
1 - 5 of 5 Posts
