So cylinder 5 has 80psi, and a shop said it's the valves. I have 87k on the odometer and I'm thinking about doing the timing chain at the same time. Should I go ahead and do it? If so, should I also get new cam and crank sprockets for it as well?
I'm trying to compile a list of parts and tools as this is my first time doing any repairs this involved, so I want to see if I have everything I need:
So firstly, let me know if I'm missing any parts. Secondly, should I get head studs or just head bolts? What's the purpose of studs instead of bolts? And can I reuse my current intake gasket? Because I can hear a leak in the intake but I'm not sure where it's coming from, I need to find out. Do I also need to set the clearance for the valve buckets again? Or can I get away with just putting each bucket back where it came from?
- Valve cover gaskets
- Head gasket(s)
- Head studs or head bolts
- Valve stem seals
- Intake gasket?
- New valves(of course)
- Lapping compound and valve lapping tool
- Valve bucket set?
