1 - 7 of 7 Posts
Need some assistance on how to go about wiring my HID fogs with the switch I have. Please reference the diagram and let me know if you have questions. I really appreciate any help.
Blue HID harness wire to purple 12volt out. Black hid to ground. Red 12volt in you can pull the power from cig lighter or from fuse tap.
Do not use the cig lighter to power the HIDs. You should have a relay connected to the lighter power connected through your switch and a heavier fused wire feeding the ballast from the relay switched contacts. This wire can be hot all the time and easiest place to come off is the fuse box terminals under the hood.
The cig lighter is not powering the HIDS, its just powering the switch. The HIDS are powered off the HID harness.
1 - 7 of 7 Posts
