1 - 20 of 22 Posts
Enthusiast
Ok, so here are the details of where I currently stand. Basically at a Stage 2.
Godspeed FMIC - Injen Piping
Dual Mishimoto Catch Cans
Mishimoto Rad Hoses
Tein S-Tech Springs
K&N Typhoon CAI
Forge BOV
CNT Single 3"
CNT 02 Housing
CNT Catless Downpipe
BTRcc Tune
CP-E Triple Dash Pod (Boost, AEM Uego, Oil Pressure)
V1
Galaxy Tab 2 with Torque & OBDII Bluetooth
Goals
It's my DD. I have the luxury of having the gen down for a period of time, but not much, 2 weeks I'd say. I try to do all the work myself just to add a little excitment to a deadline. I'm planning a full motor build in 2 phases with the ultimate goal of 500whp.
Phase 1 - shooting for 300-350whp (less is fine since this is a stepping stone)
PRW Stage 4 (exhaust manifold, turbo, extended o2, recirculated)
Evo X Injectors
Exceldyne Fuel Feed Line
Deatschwerks DW300 Fuel Pump
Grimmspeed Phenolic Intake Manifold Spacer
Custom Tune (BTR April Chicago Event)
Phase 2 - shooting for 450-500whp
Deatschwerks 1000CC Injectors
K1 Connecting Rods
Manley 86mm Pistons
270 Tomei Cams
Brian Crower Valves (not sure what size yet)
Brian Crower Springs/Retainers
Level 1 Torque Converter
Contemplating / Researching
Meth Injection
Megan Racing Engine Mounts
Unorthodox Racing Pulley Set
Koyorad Radiator
Throttle Body Spacer
Intake Manifold
Looking for feedback so no need to hold back, I'm not sensitive.
B&Ms mounting instructions advise against having the transcooler upside down. Air bubble/pocket can get in the line. Facing up or to the side are the ideal ways.
British Oreo.
:EDIT:
Never mind, my computer was being a piece of crap.
Looks good so far! In for more updates!
Enthusiast
Discussion Starter #15
:EDIT:
No worries, I ended up changing them anyways. Imageshack changed there site so I had to learn how to resize the images. Hopefully this is better.
Enthusiast
Discussion Starter #16
Just wanted to update based on the progress so far, nothing cool at this time.
PRW Stage 4 - Completed purchase. PRW states 1 week for assembly.
Evo X Injectors - Completed purchase.
Exceldyne Fuel Feed Line - Complete purchase.
Deatschwerks DW300 Fuel Pump - Completed purchase.
If all goes well by the end of March I'll start looking at the install based on the April BTR tuning event.
I'll post pictures of the parts as I get them.
Enthusiast
Discussion Starter #19
PRW Stage 4
Evo X Injectors
DW Fuel Pump
Stock Solenoid (only made this much due to solenoid failure) MBC on its way.
We have also changed the way we had the waste gate and bov recirc'd. We removed those T-s on the cold side and left the waste gate to the atmosphere.
Enthusiast
Discussion Starter #20 (Edited)
A few more images to update the build. We added an MBC to remove the stock solenoids. I left the stock solenoids connected to the ECU for now just to be sure I don't trip any codes. Talking with BTR to get a tune update so I can completely remove the solenoids.
MBC set at 19PSI.
For those of you that asked what additional parts we had to buy with the kit here you are. We plan on putting a full list together; but as we speak the build isn't done; more to come. This weekend we are doing the cooling lines.
Link to actual image where it's can be read easier.
1 - 20 of 22 Posts
